I need the two water pump sleeves, the ones that seat against the pump divider plate. Preferably from someone in Alberta?
I'm at a loss here as I do not remember any sleeves? This being said, I have the two inner divider plates the go in between the water pump and waterpump housing and I am in Ontario. Are these what you are looking for?
David
They bridge the gap between the divider plate and the timing cover and ensure that the freshly pumped coolant actually flows through the block rather than around in circles inside the water pump cavity of the timing cover.
Not a bad price from BOP. New ones from GM list for 10.35 ea.
but I think discontinued from GM.. BOP sells them with the O-ring. even thou your gasket kit has them in it. but the O-rings from BOP fit the sleeve better.
I've never replaced those before even though some needed it. They always looked like a real PITA to r&r. Do you just beat them out and knock the new ones in?
here is how I do it. I have a new pump with the steal impeller. some are cast some are steal. some people like the cast impellers, they say they pull more water. I dont know. I have used them both, and as long as you space the plate to the impeller tight. your golden.
here is a pic of one I didn't gauge, its called a steam chamber. the impeller and the plate is to far apart and it wont prime itself . it will push some coolant but your motor temp will be about 215 or higher. this one ran at 225 temp.
you can see the coolant level in the pump, the top had steam or air presser in it and the gap at the plate and impeller was to big to let the pump suck the coolant from the rad.
how to. take the pulley and use it for a stand for the pump. bolt the gasket and plate on the pump.
I use a hard rubber or peening hammer. I tap it down around the outside first to bring it down to the impeller. if you start to hit the impeller thats fine for now.
then move to the center. peen it down and turn the pump at the same time , so to here if it's rubbing the impeller. when peening the outside part first and got into the impeller the center peening will raze it up off it. if not , take it off and tap it back the other way.
I use a razor blade to gauge the space. you can get tools to check it but the razor blade work fine. I took this plate from a 1/4" gap to a little more than this blade
use a little bit of black silicone ( little bit ) put it on the gasket and use your finger. push it on the gasket and wipe you finger off as you go. if you put it on and let it mush out, you have a mess. and also the amount that came out also came out on the inside. and will at some point get stuck in your radiator.
for the Rubber Sleeves and tubes I have seen guys put silicone on them. don't . all they are for is to keep the ware of the hot coolant off the timing cover. they wont leak and if they did the water isnt going any were but in the block. putt a little oil on the rubber like you would a oil filter.
