I know someone who says you can get the 14x6 Rally II's to work with the front disk brake conversions. You have to grind down something, if I remember correctly. I chose to go with 15x7 Rally II's because of this issue. I've also heard 14x6 steel wheels are a no go with the conversions.
I'll run over to camaros plus monday. Last time i was there i saw a rally II wheel. im sure he will let my borrow to check fit issues. if its minor grinding i'll touch base with you , the rubber is 50% ?
