Case of 12 shipped Fedex , 90.00 , retail is 15 each on these .http://www.knfilters.com/search/applications.aspx?Prod=HP-2003 look up this is all the applications for this filter
These are OIL FILTERS , not air filters , this is from K&N * Resin-impregnated filter media provides maximum filtering surface for contaminant removal * Anti-drainback valve (where applicable) eliminates dry starts, prevents oil from draining back into crankcase during engine shutdown * Internally lubricated gasket provides positive seal while allowing easy on and off of filter * Rolled threads provide extra protection against stripping * Traps 99% of harmful contaminants Our oil filters use resin impregnated cellulose filter media. This allows for higher flow rates while providing outstanding filtration. High filter flow rates are important in racing vehicles where heavier grade oil is used and the oil is pumped much faster than in a standard vehicle. When the engine is circulating oil at high GPM rates, the high-flow oil filter helps reduce the loss of pressure through the filtering process.
