My car has a 1974 455 with stock oil pan. The previous owner says the dip stick is not marked correctly for the engine and that the engine builder told him to add 5 quarts and mark the stick, which he never did. I plan to add 4 quarts and mark the add level, and then add a fifth and mark the full level. However, I have heard aboout some stock oil pans with 6 quart capacities. Does anyone know what is correct?
yep. every time I see that, i think IROC. (as in CrapMaro)...
Chilton's says 5 quarts for a '74 455 engine plus 1 for the filter.
you mean its IIRW (w = wrong) lol, but the chart I have from 1973, states: Crankcase 1968-69 SE,SD , 1967 SE,SD, SC 5 qts except 1967 8 cyl, 6 qts and 1969 6 cyl 41/2 qts add extra 3/4 - 1 qt when replacing oil filter
Read the original post - he's got a 1974 455 with a stock oil pan swapped in.
Every 1 i've had(11) from 67 thru 78 had/have same size sumps. 5.75/6.0 qts w/a filter. The diff is do to the lower tube not correctly located thru the block.
