My housing leaked from overtightening throughout the years of use so I went to the locak NAPA store and purchased a new one from them. It is cast steel not potmetal so it won't warp but does not look quite the same as a oe housing. Enjoying miles of no coolant leaks now!
2002 Trans Am Coupe Sunburst Orange auto # matching 76 Black on Black Trans Am 400 Auto # matching SOLD 69 Firebird Convertible Windward Blue Auto # matching - Wife's Car 67 Firebird Coupe 326 HO Stick Mariner Turquoise - Fast and Loud 2012 Dodge Ram Red- Firebird Express 2013 Chrysler T&C - Wife's Grocery Getter 76 Trans Am - Built 455 4 speed Black On Black Very Fast & Loud 76 Trans Am SE 455 4 Speed Numbers Matching Black on Black 319 Made
Mine was warped as well. I put it in the vise and used a flat steel file and filed it flat again and always use FormaGasket to seal it up and no leaks!
I have the original and will now install. Any helpful hints to prevent it from leaking again? Rubber or paper gasket, type of seal to use, etc. Thanks!
1967 Pontiac Firebird 400 4 Speed Convertible 1973 Opel GT
I have always used the paper ones with RTV. Make sure both surfaces are very clean. I use gasket remover (be careful it will remove paint) to get it very clean. Never had one leak.
I have had nothing but heartache with T-stat housings, heater hose post clamps and fuel line flare fittings. Always seems to be a little drip. (Like an enlarged prostrate).
Tighten... re-tighten use Permatex #2 Form-A-Gasket
Thick paper is fine and no gasket sealer is necessary. Clean both the housing and intake surfaces very well and run your finger along them to feel for rough spots that need further cleaning. I always just clean them with a gasket scraper, but a flat head screwdriver can also be used.
