M Offline
Hi -
I have a complete 10 bolt 8.2 rear end out of a 1968 firebird. It is a 3.55 posi, drum-to-drum with multi-leaf spring mounts. I have had the rear since the mid 90's and it has been in storage since 1995.
I am wondering what the street value of this is, I am trying to correct my hoarding ways and get rid of a few things.
Thanks,
Matt
Richmond, VA
1 big important question:
Does it have a large raised capital "N" embossed on the top of the center section right behind the pinion yoke?
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
To clarify - if you have a 4 pinion nodular iron version of that 3.55 Safety Track rear end, it could mean a difference in value of about $1,000
1980 Turbo Trans Am
M Offline
Hi thanks for your response. I looked over the rear center section and there was no N near the pinion but there was a N raised and cast to the left upper iron webbing on the back of the unit near the diff cover - about the ten o'clock position. Near the N is a D and in the same spot on the other side is a 2 cast into the housing. I took some photos and will attach tomorrow.
Matt.
Nah, the "N" I am referring to is huge - probably about 3 inches high.
So you have a "regular" 2-pinion 3.55 posi rear for a '68.
You can perform your own search here on "posi" and go back a few years. The "as is" price for you axle with its more desirable gear ratio seems to hover between $500 - $600.
1980 Turbo Trans Am
M Offline
Thanks for your help!
T Offline
Check axle code stamped on the driver's side axle tube near the brakeline retainer, will be ZN if it's a 4 pinion axle. You may have to clean off the tube with a razor blade to find the code. I don't think any 3.55 axles were 2 pinion. 3.55 was the first of the performance axle ratios offered for all the Pontiac performance cars.
Steve
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
So if the stamp on the axel tube is 332 ZN is it a nodular? What does 332 mean?
