They are scheduled to be delivered by ups tomorrow before 5pm. Bit the bullet and bought a set from ram air restorations ent. Tuesday..... got them on eBay with bolts and flanges. Now I would like to find a good deal on pipes without mufflers. Which brand makes the best ones without modifying? Would like something that wouldn't rust up overnight..... any help would be greatly appreciated!
I was in a rush and used Eastwood header coating on my RARE round port long branch manifolds. I wouldn't recommend it. The manifolds will be taken off soon and I'll end up sending them to be ceramic coated.
Well got my 44lb package! I want to put flowmaster 44 mufflers and crossover pipe dumping out in the factory location duals. Maybe I need to give r.a.r.e a call......
Was the 8 oz enough POR 20 paint or did you get the Pint?
-Kyle
I bought the pint and have well over half of it leftover. A little goes a long way and I used 2 coats. POR-20 is heat resistant, perfect for LBM's and exhaust. I coated my entire exhaust system with it. Looks really nice when your under the car.
I used POR 20 as well, goes on like a dream and yes still had half a can left over, which I use as touch ups.
Had a little rust come thru underside but the west coast has a lot higher humidity in the winter than CO. Now I have two coffee cans with light bulbs under the hood to keep the humidity down as the shop is only heated on an as needed basis.
Pypes exhaust should be here today or tomorrow. Got warm weather plans in full swing!! New plug wires. Got a few small thing to get before I move into the garage.... HAHAHA
SOOOOO....... Looks as if R.A.R.E either forgot to process my order or didn't take all my info down..... Was supposed to received my exhaust yesterday.... Called them this morning and will have to wait until Tuesday now for answers....
