Posts: 1,374 |
They are scheduled to be delivered by ups tomorrow before 5pm. Bit the bullet and bought a set from ram air restorations ent. Tuesday..... got them on eBay with bolts and flanges. Now I would like to find a good deal on pipes without mufflers. Which brand makes the best ones without modifying? Would like something that wouldn't rust up overnight..... any help would be greatly appreciated!
Posts: 9,027 |
I got my 2.5" LBs AND pipes from Ram air. They fit well, and are not rusting even in the moist west coast atmosphere...
Oddly enough the pipes I got from RARE were made in Canada, a long trip back and forth for them!
Posts: 2,157 |
Got my LBM's and exhaust from RARE as well. Used Por-20 on all of it and not a speck of rust 3 years later.
Posts: 2,113 Likes: 1
Posts: 2,113 Likes: 1 |
I was in a rush and used Eastwood header coating on my RARE round port long branch manifolds. I wouldn't recommend it. The manifolds will be taken off soon and I'll end up sending them to be ceramic coated.
Posts: 1,374 |
Well got my 44lb package! I want to put flowmaster 44 mufflers and crossover pipe dumping out in the factory location duals. Maybe I need to give r.a.r.e a call......
Posts: 313 |
colorado-
Was the 8 oz enough POR 20 paint or did you get the Pint?
-Kyle
Posts: 1,374 |
Isn't por20 heat sensitive? I was thinking of using a kbs product on them.
Posts: 2,157 |
I bought the pint and have well over half of it leftover. A little goes a long way and I used 2 coats. POR-20 is heat resistant, perfect for LBM's and exhaust. I coated my entire exhaust system with it. Looks really nice when your under the car.
Posts: 9,027 |
I used POR 20 as well, goes on like a dream and yes still had half a can left over, which I use as touch ups.
Had a little rust come thru underside but the west coast has a lot higher humidity in the winter than CO. Now I have two coffee cans with light bulbs under the hood to keep the humidity down as the shop is only heated on an as needed basis.
Posts: 1,374 |
Pypes exhaust should be here today or tomorrow. Got warm weather plans in full swing!! New plug wires. Got a few small thing to get before I move into the garage.... HAHAHA
Posts: 9,027 |
..."THE DOGHOUSE"
Posts: 1,374 |
Best doghouse I've ever seen!!!
Posts: 1,374 |
SOOOOO....... Looks as if R.A.R.E either forgot to process my order or didn't take all my info down..... Was supposed to received my exhaust yesterday.... Called them this morning and will have to wait until Tuesday now for answers....
Did you talk to Paul directly?
Posts: 1,374 |
think so..... Charge finally showed up on my card last night.... Fingers crossed I get it sometime next week.
2 members (Geoff, Jimc2002),
469
119
