Looking for instructions/advice on how to bleed the air from my 69 power top hydraulic system. I have the rear seat out and can see lots of air pockets in various parts of the lines. The top goes up and down fine, but will not stay partially raised for too long before settling back down, one side somewhat before the other. No leaks of fluid evident anywhere and fluid in the lines appears red like Dexron fluid (as I believe it should).
First of all, should I even bother to worry about the air in the lines?
This priming operation is necessary prior to performing the following steps in order to avoid drawing excessive amount of air into hydraulic system. 4. Install filler plug adapter to reservoir and at tach four or five foot length 5/32 inch I.D. rubber tubing or hose to filler plug tubing. 5. Install opposite end of hose into a container of Type "A" transmission fluid. NOTE: Container should be placed in rear compartment area on "A" bodies and rear floor pan on "B-C & F" bodies, below level of fluid in the reservoir. In addition, sufficient fluid must be available in container to avoid drawing air into hydraulic system. 6. Operate top to down or stacked position. After top is fully lowered continue to operate motor and pump assembly approximately 15 to 20 seconds, or until noise level of pump is no ticeably reduced. Reduction in pump noise level indicates that hydraulic system is filled with fluid. 7. Operate top up and down several times or until operation of top is consistently smooth in both up and down cycles and no further air bubbles are exhausted in container or fluid. 8. With top in down position, remove filler plug tubing and remove filler plug adapter from reservoir. 9. Check level of fluid in reservoir and re-install original filler hole plug. NOTE: Fluid level should be within 1/4 inch of lower edge of filler plug with top in down position. CAUTION: DO NOT OVER-FILL.
Th
When I put new seals in my actuators I was very careful to get all the air out. Actually filled the actuators, installed them in the fully extended condition and purged all the air out of the lines before connecting, etc. You know what, after a while, I find air pockets throughout. My opinion, if it goes up smooth and evenly, I wouldn't worry about the air.
