#285720 03/09/14 11:01 PM
M Offline
the plates over the windshield and rear window that the headliner attaches to how are they screwed in the holes seam pretty big is there plastic pieces that go it the holes first any pics?
[Linked Image from i64.photobucket.com]
Tim Malmstrom
Not sure what plates you are referring to. As far as I know the headliner is just glued to the inside edge of the roof line and wrapped into the window channel. The there is a rubber trim "U" channel that is pressed on over that to hold it in place. Same at the rear window.
The front two pieces use a pan head type screw. The back three pieces use a T style metal retainer. I used plastic interior plugs that you can buy at your local auto parts store in the HELP section.
The brackets that (Firebob) are referring to are the pieces that the head liner wrap up into on the front and back of the car. They have those small little sharp metal tabs that help hold the headliner in place.
M Offline
yeah what firebob was saying the hole that the screw would screw into ar a pretty good size though just was not sure if there was a nylon plug that went in there. hopefully the guy installing will know i just wanted to make sure i had every thing first
Tim Malmstrom
M Offline
it is like a T clip what i am looking for i still had one in one of the holes
Tim Malmstrom
Just use plastic push in interior clips. I could not find the t clips reproduced. The plastic push in clips hold the brackets better than the t clips.
http://www.oreillyauto.com/site/c/detail...9&ppt=C0329
M Offline
Thanks Robert !
Tim Malmstrom
