The only way I have seen either the inner or outer rear wheel housings replaced is after the outer quarter panel is removed.
I replaced the outers without removing the quarters. I cut the old one near the center seam and drilled out the spot welds in the wheel. I had to cut the new outers to fit and seam welded them in place. Once the wheel wells were undercoated it is very hard to see the repair. From the truck side it is virtually invisible.
