Not real recently but close enough that I might be able to help.
From the instructions I reuse the horn contact plastic piece and modify it with the contact plunger that comes in their kit. I've been messing with it on the kitchen table to try to figure how all the pieces go together.
My install was on an aftermarket column so I was not retrofitting. I ended up using all their horn parts. We need to get somebody better qualified for your situation.
I put one in my 68, modified the horn contact as they instructed and my horn works, sometimes. I had the wheel off five or six times then went on to other things and never did get it operating correctly. I know that doesn't help you, but you're not alone.
