Hi guys, I'm putting a 1971 400 in my 67 firebird with Long Branch exhaust, the angle oil filter housing I bought from Kauffman racing does not work as the exhaust hits the oil filter at midway on the filter. According to some research I need the 1966 GTO filter housing that is at a 120 degree angle. Anyone have one, know where I can get one or a way to fix it without returning the Longbranch ad going stock manifolds. Thanks text me at 949-795-193three if you have one. Engine is on the EZ run stand waitng to fire up.
Not sure exactly what it is you need but I think I have a housing from a big car that is tilted in toward the block instead of the normal bird one that was 90* down.
I've got a 70 block and use the exact same adapter Gordy shows.. so I know it fits. Also have the LBM's and TH400 The filter housings came in 90 and 105 degree. You just need the 90 degree housing and the adapter and it will clear.
