Never thought attaching the radiator shroud correctly would be so challenging. The mighty internet has 3 different ways (all OEM factory correct) to attach this thing. The Assy manual has 2 u shaped brackets on the bottom, not shown here. Which one is the right one for a 400, convertible, if that even makes a difference? I know the top metal bracket is correct, what's on the bottom of the shroud or center?
Thanks Harold. How many clips total? So u shaped clips none of the s shaped right? And the large fastner goes on the passenger side? Sorry, the diagram is hard to read. Any links of the correct ones would help also.
