The 1st holes on both sides of the body that the rocker panel molding goes in, the original screws just go right in they dont screw in anymore. how can i fix this or do i just but a bigger screw?
also how do the brackets go on for the moldings? if anyone has a pic that would help. thanks
1967 Firebird coupe, 396 big block, 700r4 2002 camaro ss
If the sheetmetal is just pulled out around the hole and you can get at the back of the panel, you can hammer and dolly the hole area flat again and the screw will grip again. Or use a bigger screw. Not a 67 guy, but I think those brackets just go on with sheet metal screws.
