68 standard int door panel emblems
296832
03/28/15
11:16 AM
Apr 2014
da
68strokr
68strokr
Apr 2014
da
I was placing an order for other stuff and went ahead and bought these;
http://www.classicindustries.com/product/firebird/parts/fb018a.html
What is the correct way to mount these?
Just push em in? Drill small pilot hole? Any adhesive?
1968 Firebird 400 coupe
verdero green/blk interior
Re: 68 standard int door panel emblems
68strokr
296838
03/28/15
01:04 PM
Feb 2004
Cedar Rapids
rohrt
rohrt
Feb 2004
Cedar Rapids
They glue on. I don't know the best glue to use but I know what glue not to use. I used the weather stipping adhesive and when it gets hot it slides off. I need to pull them off, clean them up and try again.
68strokr
297081
04/04/15
02:25 AM
Apr 2014
da
68strokr
68strokr
Apr 2014
da
I ended up using loctite Super glue - "Ultra Gel Control". Seems to have done the job. Only time will tell.
68strokr
298297
05/15/15
11:55 PM
May 2015
Pa
Jef
Jef
May 2015
Pa
I've cleaned off the back of the emblem and the door panel with grease oil remover the applied 3M tape worked fine
68strokr
298370
05/19/15
04:35 PM
Jan 2009
Elk Grove, California
Jan 2009
I've used Amazing Goop for years, and it's never let me down...door panel emblems on for over 6 years and no issues.
Amazing Goop
68strokr
298488
05/25/15
10:51 PM
Jun 2003
Low Country
FirebirdMike
FirebirdMike
Jun 2003
Low Country
Which one? This is the route I want to try.
68strokr
298518
05/27/15
05:18 PM
Aug 2005
Rexford, NY
P
Pete
Pete
P
Aug 2005
Rexford, NY
I used Amazing Goop as well.
Pete
1968 350 Coupe, Verdoro Green
Jef
298562
05/30/15
12:04 AM
Jun 2003
Low Country
FirebirdMike
FirebirdMike
Jun 2003
Low Country
Shoot, I quoted the wrong person. I want to try the two sided tape as well. Which one did you use?
68strokr
299332
07/06/15
01:25 PM
Feb 2004
Cedar Rapids
rohrt
rohrt
Feb 2004
Cedar Rapids
I used the "Amazing Goop" based on you guys and I'm pretty impressed with it.
Door emblems are nice and tight. Time will tell how they hold up. I'm using the Goop around the house too.
07/06/15
01:26 PM
Website
Website
Website
0 members (), 459 guests, and 17 robots.
