#298796 06/09/15 11:52 AM
Ok pontic head gurus here's my issue. I have a pair of '69 heads with a casting number of "62" These should be for a '69 400/428 4bbl. I need an exhaust, but all I've been able to find are to short. The original valve are 5.080" over all length, but the replacemets I've found are only 4.972" overall length. Everything else is correct 1.77 valve with a stem diameter of .340 The shorter length is my concern or is it just my retentive side coming out
Thanks
Try Ferrea F5144...thats what I use. They are 3 hundreths longer...and I usually take some off the stem anyhow...easier to be longer than shorter.
I have a few sets of used stock valves in great condition if you wanna go that route. Just pm me an address. I'll head to shop today or tomorrow to check valves and true up the seats.
Si Vis Pacem Parabellum
1968 Alpine Blue 400 4 speed
O
O Offline
SI has a 5.085 inch 1.77 exhaust. It's part number 6003SG. smile
http://www.sivalves.com/ocdomestic_valvescs_pont.html
