I am trying to get my wiper motor to work. I know the switch is a negative ground. I have three plugs on the motor. Each one has 12V at all times. Which wires get grounded to activate the motor?
And you will when the #1 yellow ignition switch is turned on there should be power everywhere Then the wiper switch will complete circuit to ground, either on the #1 blue wire for high speed or the #2 light blue and #1blue both for low speed
