Posts: 244 |
This is all from my basement. Contact me with questions or if you want pics. $20 New ACCEL Super Stock Performance Wire Set 8mm #4041K $20 400 CI Distributor #111223 2F15 June 15, 1972 $25 New Pontiac Fan Spacer with Bolts. #535-253 2- 1/2" $65 GM Anti Surge Vented Gas Cap in perfect condition. Group No 3.028 Part # 3843698 $170 Original Kickdown Switch #9785545 with Bracket $ 130 Performance Suspension S-18718 Idler Arm S-ES681n Sway Bar S-ES981n Front Inner Tie Rod End S-ES381R Front Outer Ball Joint S-10197 Front Lower Ball Joint S-10195 Front Upper Ball Joint GM Front Control Arm Bushings 4each 13001G Tie Rod Boots 2each 13010G Upper Ball Joint 2 each 13009G Lower Ball Joint $20 Each Pulleys 481038YB 9790846YA 480509XS 481040XT 4964YP 496411YP $20 Crane Cams Adjustable Vacuum Advance Kit. New in box $30 Steering Pump Bracket #9786903 Good condition $10 Air Cleaner Vent Tube Without Ram Air. Looks like new. $50 For ALL 1 ea 1967 #214 Standard Front Lap 2 ea 1968 231 Standard rear Lap 1 ea 1969 #2910 Standard Rear Lap 1 ea Front Lap Belt with Retractor 38" (Tags removed) 2 ea Lap Belt Retractors $35 Center Dash Panel In good condition Without AC $60 68-69 Burl Wood Console with Auto Shift Plate. Not perfect but salvageable. All above dollar amounts are plus shipping. I will combine shipping.
Posts: 10,337 Likes: 3
Posts: 10,337 Likes: 3 |
Posts: 39 |
I'm interested in the console. Can you send a pix if you still have it?
Thanks Dave
Posts: 244 |
I have pictures but I don't know how to put them on this site. I can email them.
New Member
New Member
Posts: 2 |
Kurt, please text me a picture of the center console. very interested 3606073143
New Member
New Member
Posts: 2 |
perfect. please email them to devenk89@gmail.com
Posts: 14 |
Is the kickdown switch with bracket still available? If it is, is the switch good electrically? Email pics to chadamz@sbcglobal.net Contact number 6307156006
Posts: 82 |
Is the $50, front and rear, lap belt package still available? Are they black?
I pm'd my email address for pictures. thanks
Posts: 74 |
I would be interested in rear lap belts for 68 if in good shape, PM'd email... thanks
Posts: 244 |
All lap belts are sold. The Kickdown switch is sold and the center console is sold.
Posts: 42 |
Hi do you still have the: $170 Original Kickdown Switch #9785545 with Bracket? Is this for a 68?
Posts: 244 |
1,607
119
