Bad thing about the 67 intakes is they don't have the provision for the therm switch on the water cross-over pass side. I have a 66 GTO intake that came with an AFB. Not sure if the carb bolt spacing is the same as a Qjet.
Hi Robert I saw that manifold Unfortunately I too am not sure. I was a BIG early GTO fanatic some years ago... sigh.. The carb bolt spacing should be the same between the Quadrajet and Carter.
