#304823 04/04/16 12:14 AM
Built this engine test stand based on some plays I got off ebay + other things I added.
Learned a lot about building things with steel and mig welding.
hey I know those gauges.... Looks great man!
RUNNIN' WITH THE DEVIL
Really cool! I'm looking at fabbing a half assed stand just to be able to assemble my motor and clutch/tranny without smashing the oil pan.
U
U Offline
I wish I had the tools to build one. I will need one pretty soon once I get my engine back from the builder! Hell, I have some drawings off the internet and I cant even find someone here in this small town who will even build it for me frown Good job on it Gus!!
You got it Pontiac!
Thanks
I built something for that as well...
It mounts onto the engine mount . Bolt her down with bolt from engine mount.
Thanks
C
C Offline
That is really a nice job on the test stand.
USMC Ordy. I cannot fathom any rural area not having a welding shop nearby. If you were closer I would help you build one.
How about a vo-tech college near you? Some of them offer welding classes, and they would know someone who could weld it up for you. How about checking for the nearest welding supply house? They would know local welders. Or try posting on Craigslist...
Cal
Sweet Gus, I need another engine to play with!
David
68 Droptop 400 4 spd.
That's very cool. Not to knit-pick but I had always been told that if you ran an engine with no manifolds like that you would warp the valves when they cooled off too fast after you shut it down. Might be BS. Just what I was told.
J Offline
I'd planned on using an old subframe but yours is more compact, might have to rethink my plans
Jerry Tallman
69 455/4sp Windward Blue, deluxe parchment bench seat, under major restoration
je_tallman@yahoo.com
Going to use it to recondition my 400HO, 389, 350HO engines.
Easy to work on and no bending over. I'll still forever to get things done but that's ok.
DID not know that. Did not run it very long but I will put a manifold on now. wanted to do exhaust and mufflers but too expensive.
I thought of using a frame as well but not worth it, take up too much room, heavy, hard to move and more difficult to get at. I'll take some pics and post them.
U
U Offline
Cal
Hey Cal, that is a great idea!! I never thought about contacting the community college welding class and see what they would charge for the supplies and do it. Thanks man!!
Good casters are the expensive part.
Here are some pics...not sure what happened to the original ones??
EngineTestStand.jpg EngineTestStand LHSide.jpg EngineTestStand RHSide.jpg EngineTestStand ControlPanel.jpg
