I'm wondering if anyone has a suggestion for installing repro door panels. The passenger side went on fine and looks very good. Moving to the drivers side I had no such luck. I can hook the top of the panel to the ridge on the door but I can't get it to come down as far as I could on the passenger side. I don't see any bends in the repro panel. I squeezed flat two edges of the ridge that were sticking out and moved back the felt lined brackets that put tension on the window. Close but not yet right. Can anyone offer any advice on this? Thanks, Doug
did some more straightening on the door and the repro panel, moved the glass guides back toward car's interior and left of the bracket up toward the front of the door. All is well now.
