I'm not sure what to even call them, so that's no doing me any good in my search, but they are like little body mount rubbers with a bolt in the middle, the close up shows one bolt is rusted off.
Radiator Support Gusset Bushing
Ames Gusset Bushing
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Thank you Salmon!
You're welcome. I'm willing to bet if the upper stud rusted through, the thick steel header panel beneath those bushings are probably pitted pretty good too.
When I put mine back together, I put a big dab of wheel bearing grease under the bushings in an attempt to prevent that from happening again.
1980 Turbo Trans Am
