I am restoring a 68 coupe and installed new wiring harnesses. I also purchased a light bulb set from CI. The problem I have is that there was no chart provided to identify which bulb to use where. On the rear light, I'm not sure what goes where. Is there any guide that identifies the bulb type or number like 1157 or 1156? Could not find anything in my Assembly Instruction Manual or in the Service Manuals or the electrical diagrams. Thanks for any help on this. Henry
I consider the front indicators and brake lamps not bright enough, particularly in daylight .... anyone replaced the 1157 bulbs with the brighter 2357 or P3496? Much of an improvement?
