J Offline
My carburetor for my ohc 6 is in need of replacement. the threaded hole that holds the small filter is stripped. Anyone have one of these?
Thanks in advance
Jeff
Maybe this thread will help. Pun not intended.
https://firstgenfirebird.org/forums/ubbth...true#Post102443
'68 400HO Conv.
J Offline
thanks for the link. That is exactly what I needed to at least fix mine, since i can't find another at the moment
I have a couple 1bbls available. What year? I believe I have the other parts you need also. Let me know. Thanks
J Offline
1968, OHC, 3 speed on column. what do you have ?
thanks
Jeff
For sure I have a 67 1bbl carb, and flywheel available. A lot of other misc OHC parts. Shoot me a PM with your needs and location and I'll check to see what I have.
Thanks,
Rob
J Offline
Do you have have the parts for this transmission, part 7 (that whole little assembly?). I have part 24, just need the rest..
I do not have the 3 on the tree parts you are looking for. I am checking with a friend who's dad restores Camaros and Firebirds. He may have what you need.
This is what you need, correct? This was off my column shifted automatic 68 bird.
If this is what you need email me at brian_young1@msn.com and let me know where to send it.
Brian
J Offline
that looks right, but I wonder if there are any minor differences with mine being a manual and that being an automatic ?
I'm not sure. I'm happy to send it to you, and if it doesn't work, you can send it back. It looks identical to the picture you provided. The rods may be different, though.
Let me know if you'd like to give it a try.
Brian
