New Member
New Member
M Offline
1969 Trans Am / Firebird parts for sale. These are all GM original parts:
TA Hood bare hood, no tunnels or scoops 7000
TA Upper Ram Air Pan 1650
TA Hood Tunnels 800
TA Hood Scoops 1300
TA Extractors 1600
TA Spoiler, nice with no bow or dip 2000
Tach and gauges/ step gauges w/ circuit board, completely restored, everything working 2500
Ram Air III long branch exhaust manifolds/ pair 950
fold down rear seat complete w/ hinges, latch, bumper, metal gutter 800
power seat w/ switch brkt and switch 950
power antenna complete w/ mounting brkts, works nice SOLD
am/fm mono. not tested 400
am/fm stereo w/ multiples and brkt tested/works 900
power windows w/ wiring most switches 800
4-spd pedal assembly 165 SOLD 2 LEFT
subframe 500
bell housing 125
4-barrel intake 125
4 barrel intake, 48 heads (lite porting) and water pump all / may date codes 950
1111946 dist 115
722 heads bare, extremely nice, no porting and not milled,. like nos 4500
RA IV Long branch exh manifiolds 1750
RA IV heat shield like NOS 450
3:55 posi nodular ZH code 2500
3:36 posi nodular ZG code 1600
3:23 posi ZF code 750
Firebird original upper pan flapper assembly 1200
400 hood 950
interior parts
mint used rust free doors 500 each
following parts are ALL GM NOS Parts: Core support 600, hardtop qtr panels pair only, will not split up 2800, sill plates 200, core support bushings 250, qtr glass vertical chrome/pair 200, roof rail weatherstrips 2000, all 4 fuzzies 550, wood shift knob 700, auto shifter PRNDSL read out display 125, tail light panel 700, roof rail stainless pair 300, full set of 4 body bushings 550, power antenna mast 450, 2 piece conv top header moldings 1150, wiper motor 350, door skins pair 850, TA Fender extractors, yes NOS 2400, conv rear top 2-pc pinchwell moldings 1100, 400 chrome grill surround pair 400, gas tank 600, convertible top latches pair 600, front 400 bumper 650
Much more and too much to list. PM me with requests and want list. will work with you on package deals
M Offline
Wow,
The motherload of parts!!
hey Trump can I get a loan ?
M Offline
I have seen his stuff.
This is the real deal and I will gladly take pictures and forward to you.
Super clean parts and then some!!!
Originally Posted By tinindninkc
Wow, glad I bought my 3.55 posi for $600! The RA III long branch manifolds are WAY over priced, as is much of this!!!
Just sayin'...
This is a 'for sale' section, not a discussion section. If you don't see anything you are interested in purchasing, please move along.
Thanks!
4 Offline
pm sent
T Offline
Noted!
PM sent
PM sent
Cme469
these must be in the box stuff
P
New Member
New Member
P Offline
pm sent
Hi Mark, How much for the 69 Power bucket seat assy w/ switch less seat? Is unit in good shape? been tested? Thanks Frank69
Hey Mark, Could I have pictures of the Power seat & assy for sale? Thanks Frank69
New Member
New Member
J Offline
Hey do you still have folding rear seat? I need the side hinge mechanisms so ill take it. 2 years ago so If gone its gone
W Offline
Anything different with 69 rear ends from 68’s? Have a 68 400 HO, but had a 12 bolt with 4:10’s under it when purchased, would like to find something different with 3:55 or higher.
J Offline
Interested in the gauges if still for sale
I have a 3:55 OEM ring and pinion set for 68/9 Firebird. PM me if interested.
