ST300 question
ST300 question
31292
06/26/05
10:03 PM
Mar 2004
Michigan
Mar 2004
Michigan
What is the mode of operation of an ST300 trans if the vacuum line to the carb is cracked/disconnected?
Vikki
Restoration Gallery
http://thefirstgensite.com
Re: ST300 question
31293
06/27/05
06:25 PM
Mar 2004
Burton, MI
verdoro326HO
verdoro326HO
Mar 2004
Burton, MI
Vikki,
I drove mine with no vacuum line for a short period of time. I never had it above 45 mph so it was always 1st gear anyway. I'm not sure if this is what you are asking though.
Derek
\'67 326 H.O. projects
Re: ST300 question
31294
06/27/05
10:50 PM
Jan 2004
Didsbury, Alberta, Canada
TOHCan
TOHCan
Jan 2004
Vikki, it acts like it's at full load. The trans sees the low/no vacuum as open throttle and shifts accordingly.
Re: ST300 question
31295
06/27/05
11:11 PM
Sep 2004
Phoenix, Arizona
68HO350
68HO350
Sep 2004
Phoenix, Arizona
I had my ST300 rebuilt recently. The vacuum line to the carb is not hooked up. The trans seems to work perfectly. Will this cause problems?
Re: ST300 question
31296
06/28/05
04:03 AM
Mar 2003
moncure, nc
sixstarved
sixstarved
Mar 2003
moncure, nc
i dont understand how it could shift right without the modulator Don.... are you sure there is none and that you have each gear when you should?
i would still hook it up. it's not there just for looks, although i think they do sell chrome ones
scott /
Re: ST300 question
31297
06/28/05
03:31 PM
Sep 2004
Phoenix, Arizona
68HO350
68HO350
Sep 2004
Phoenix, Arizona
Thanks Scott. It sounds like the transmission is getting vacuum from somewhere, maybe the back of the manifold??? I will look closer this weekend.
1stgenbirdman
Website
Website
0 members (), 603 guests, and 32 robots.
Highlander
May
