Inner fender well clearance 1969 Firebird
321834
03/27/19
02:45 PM
Nov 2011
colleyville, tx
Stripes
Stripes
Nov 2011
colleyville, tx
I'm planning on narrowing a 12 bolt rear for my 69 FB.
How much clearance for the tire is typically required between the sidewall of the tire and inner fender well?
Would 1/2" be enough? I don't want to rub the inner fender sides, but want to maximize space for larger tires.
I'm considering a 59" hub to hub 12 bolt, plus 1/8 each side for the drum thickness. The OE 12 bolt was 59.75" plus the drums.
Has anyone narrowed their FB running a 12 bolt in a non-aftermarket tubbed situation? What width did you go with?
0 members (), 2,140 guests, and 37 robots.
Highlander
May
