Ignition Coil specifications
322376
05/10/19
10:24 PM
May 2019
Holly Springs
FGBIRD67
New Member
FGBIRD67
New Member
May 2019
Holly Springs
Does anyone know of the resistance specifications for the ignition coil off a 67 400? Having a no start problem and trying to determine if the coil is the issue. Primary side tested at 1.4 and secondary at 9.6k. thanks
Re: Ignition Coil specifications
FGBIRD67
322378
05/11/19
10:54 AM
Jan 2009
Elk Grove, California
Jan 2009
Looks like your secondary side is WAY out of spec.
Here's a good article;
http:/
www.secondchancegarage.com/
public/
coil-troubleshooting.cfm
FGBIRD67
322381
05/11/19
01:30 PM
Oct 2009
Virginia
hokie1984
hokie1984
Oct 2009
Virginia
Here are the factory specs. Looks to me like the primary side is out.
http:/
thefirstgensite.com/
library/
67service/
PO67S6EP25_51.pdf
Larry
1967 Sprint Convertible
1stgenbirdman
2 members (
Pete67400
Bob S.
), 418 guests, and 20 robots.
