#324023 09/22/19 03:27 PM
What size tires are you guys using? I tried a 255/60/15 on the back and I get a little rubbing. My tires are bad so it's time to go to 15s. Any fit problems with factory calipers?
67 Firebird 400. 30k orig miles, 4 speed, ps, pb, pw,
front disc brakes with dual piston calipers, ac, hood tach, triple black.
235/60R15 front and 255/60R15 back, Rally II with BFG radial TAs. Don't know about factory calipers I have single piston calipers on mine.
Agree with a max of 235/60R-15 for the front
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
I shouldn't have listed the rear tires. I have a Camaro rear in mine, it's an inch narrower than the BOP so I've a bit more room for rubber.
I just put 235 60 15 on the front of a 69 with rally II's, I have the factory calipers with on issue,
just a little rubbing when turning a certain way but I have to look at the front coil springs, do need to change
the shocks up front
