#327710 09/06/20 11:11 AM
C
C Offline
Wonder if anyone knows exactly where the outer wheel well attaches to the quarter panel? My car has detached outer wheel wells with new quarter panels so I’m not exactly sure where they are plug welded onto the quarter. Photos would be great, but basically I’m asking, are they flush with the quarter panel wheel opening or is there a margin? Thanks.
P
ped Offline
P Offline
Drill 5/16" holes in quarter panel lip about every 2-2 1/2" & plug weld.
68 coupe
Purchased 8/5/13
ped #327719 09/07/20 02:10 PM
C
C Offline
Thank you for the information. Perhaps I’m asking the wrong question.
This is what I’m currently dealing with. A complete thief of a body shop installed new quarters onto my car and really butchered the inners and trunk extensions. My issue is when I do my mini tub and outer wheel well, I’m not exactly sure where they line up.
Basically, is where these outer wheel wells lining up correct or do they need moved? Thank you.
P
ped Offline
P Offline
Well in your pic it looks like the B-shop left the lip from the old qtr. panel, which was welded to the outer wheelhouse, then tried to attach it to the new qtr. panel. If I'm correct IMO replace the outer wheelhouse when you do your mini-tube install.
68 coupe
Purchased 8/5/13
ped #327742 09/09/20 11:32 PM
C
C Offline
That’s what I’ve been doing. It’s a lot of work but one side is done. Thanks.
P
ped Offline
P Offline
Detroit Speed mini tubs ?
68 coupe
Purchased 8/5/13
