Posts: 95 |
I have tried several 15x7 rally’s and they all rub with my 4 piston factory calipers. Can anyone verify that a 15x8 rally will not rub?
67 Firebird 400. 30k orig miles, 4 speed, ps, pb, pw, front disc brakes with dual piston calipers, ac, hood tach, triple black.
Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
Hmmm. Hard to believe any 15’s rub. I’ve got 14’s that don’t rub my single pistons
Posts: 18 |
How much do they rub??? Could you grind down the caliper with a grinder??? That would save you from buying another set of rims, if the caliper is painted you would have to repaint them but that shouldn't be to hard to do yourself and no one would ever know, I know of some guys that had to do that to get there wheels to fit
Rob Acon
Posts: 95 |
I would prefer not to grind down the factory calipers. My 14†rally’s do not rub. I will probably use a spacer. But I only need two 15x8 rims if they would clear.
1 members (airram),
1,462
111
