Hi Guys, I just converted my 67 to power steering. I bought the brass flare inserts to install on the power steering box to accept the flared SAE flared hoses. The high pressure fitting on the box just does not seal. If I tighten the fittings, I can still move the hoes and it leaks. I know there are o-ring to male flare adapters I can use, this would require a hose with a male flare fitting (ps pump) and a female flared fitting (steering box). Has anyone had this problem and where can I find the p/n for the hose?
