Just a general knowledge question to the community.
'68 400 motor, rebuilt about 3,000 miles ago by owner #2. I am owner #3.
D298 code on block (April 29, 1968 production date) D298 code on right head (same day of production) D048 code on left head (April 4, 1968 production date)
I had read that the head codes may not match, yet still be original for that block. Did they have a pile of age appropriate heads to grab from while building a motor at the factory in 1968, or is this April 4th 1968 head a replacement over the car's 50+ years ???
My guess is that it could be the original head. The date you see is when the head was cast. After that, it went for maching of the valve seats, head gasket surface and so on. Then, it went for assembly of the valves, and all the related things. Between the different operations, the head was probably stored at different shelves or in storage rooms. The operator that was to machine a head wouldn't care what the date code was, has probably grabbed the nearest part and put it in the machine.
Since the date codes are only a couple of weeks apart, I would assume it is the original head to that engine.
