Howdy. Just in triage mode with my 1-day old Firebird acquisition. First annoying feature is the door buzzer goes off when either door is open independent of key position or key out of ignition entirely.
It will go off if I manually push the door switch, but I suspect this may something more sinister like a short or failed component wherever this door switch is run through (steering column?).
If anybody has any first-hand experience and/or can make some suggestions for debugging, I would be most grateful. My Kung Fu for electrical issues is about 5/10 (10 being a grand master), so I'm willing to fire up a volt meter, but thought I'd check in here first.
Thanks for listening!
Tommy D
1969 Firebird, 350-2v/350, Verdoro Green (?), Green vinyl, numbers matching, relatively unmolested. Needs a bit of everything.
My 1969 Firebird has the same problem. When you put the key in the ignition lock, the key push on a little pin that operates a little switch (example picture: https://www.amesperf.com/parts/46740/) that sets off the buzzer. In my case, the pin seems to not move back after it has been pushed in by the key. I have tried to solve it once, but it involves taking the steering wheel off, then the plate for the steering wheel lock to get to the lock cylinder and the switch. It worked a little while, but then started to act up again. My solution so far has been to disconnect the plug on the horn relay/buzzer (on the firewall). If I remember correctly there are two plugs on the relay/buzzer. I mean, one plug for the horn relay function and another for the buzzer function, so you can disconnect the buzzer and still use the horn.
1969 Pontiac Firebird 400
1966 Chevrolet Corvair Monza
Thank you, Ronnie. Very much appreciated. I will update with my findings/solution.
