#334652 09/18/24 09:11 AM
dfb
Offline
Looking for advice on replacing the blower motor on a 69 convertible. Everything is painted and it is a fully assembled car. Is just wheel well housing removal possible or is the fender/wheel house removed together? I am not interested in cutting a hole to gain access. Thank you.
Pull the hood and then the outer and inner fender as an assembly.
dfb
Offline
Thanks Jeff. As I visualize doing this, I assume the front bumper assembly is off also, correct?
No, you should be able to leave it in place.
