Posts: 5 |
Complete 4-speed assembly - Removed from 1967 Firebird project - customer wanted AOD - Car had less than 500 miles on transmission, clutch and shifter - Transmission is new 'crate' M23 heavy duty rock crusher from Auto Gear with the wide ratio gear set - 2.52 low - New transmission crossmember - New Mcleod clutch - 11" HD single disc with diaphragm - New Hurst Competition Plus Shifter - OEM clutch and brake pedal assembly - OEM fly wheel and bolts - OEM Z bar, bracket and spring - OEM linkage and boot - Neutral safety switch harness (no switch)
Why waste time and money trying to find all the parts needed to convert your ride to a 4-speed when you can buy it all here. Located just outside of Louisville, KY. I have it boxed and skidded up. I can drop off for free at any of numerous freight depots in Louisville or may consider meeting in person at a reasonable distance (150 miles or so).
$2,800 for everything
Contact James 502-931-2715
Posts: 5 |
Motivated seller, make me a reasonable offer. Give yourself an early Christmas present, you deserve it!
Posts: 5 |
1,607
119
