J Offline
Complete 4-speed assembly
- Removed from 1967 Firebird project - customer wanted AOD
- Car had less than 500 miles on transmission, clutch and shifter
- Transmission is new 'crate' M23 heavy duty rock crusher from Auto Gear with the wide ratio gear set - 2.52 low
- New transmission crossmember
- New Mcleod clutch - 11" HD single disc with diaphragm
- New Hurst Competition Plus Shifter
- OEM clutch and brake pedal assembly
- OEM fly wheel and bolts
- OEM Z bar, bracket and spring
- OEM linkage and boot
- Neutral safety switch harness (no switch)
Why waste time and money trying to find all the parts needed to convert your ride to a 4-speed when you can buy it all here.
Located just outside of Louisville, KY. I have it boxed and skidded up. I can drop off for free at any of numerous freight depots in
Louisville or may consider meeting in person at a reasonable distance (150 miles or so).
$2,800 for everything
Contact James 502-931-2715
J Offline
Motivated seller, make me a reasonable offer. Give yourself an early Christmas present, you deserve it!
J Offline
SOLD
