Having owned one after high school I intended to build a nice daily driver to replace it many years later but haven’t been working on it and don’t want to be the one that lets a classic go to waste. So… located in western MA asking 8500
She is a 67 with a clean MA title but in no way a matching numbers car. The suspension is from a 68 coupe. The engine and trans are from a 70? 71? Buick. 350, untouched, hasn’t run in over 20 years, I just cleaned and painted it and figured I’d run it til it broke, only grabbed it for the turbo 400 trans. Originally was a 326/powerglide. No front body clip. Most of the body is now dynacorn, new one piece floor and trunk, frame rails, seat support, firewall, inner and outer wheel wells, rear valence. Quarters are Goodmark. Underside is Eastwood epoxy primer and undercoating. Doors are original and in need of either a lot of work or replacing. I have the top frame, likewise in need of restoration and needing a new header where it meets the windshield frame. New body mounts, new A arm bushings installed, front disc brake conversion, sub frame cleaned, POR15 and painted. I have some small parts like heater box, fuse box, and tail lights but most of the interior was in rough shape and went away. She still needs a lot but could be a great starting point for someone wanting a solid project.
