I know my timing is not right. Getting on it in 2nd gear, it starts cutting out in mid-range. I have a '67 bird with a 68 400, 375 cam, 4X heads, Edelbrock Performer and AFB knockoff, and 77 HEI. 4-speed M-20. Any tips for initial timing, total timing, mechanical and vacuum advance? Haven't found a timing tape for the harmonic balancer. It's a warm weather (Houston) car.
Schwee, this thread may help a bit: https://firstgenfirebird.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=23;t=002055
But typically I start it out at about 9 degrees BTDC... But I'm still using a points Dist. So I set the Dwell at 30, initial timing about 9 BTDC and go from there...
I think Vikki's thread above may be closer to your combo, so read the first few entries?
I'm sure some one with better info will chime in soon!
The first step is to make sure everything is operating correctly. That means the mechanical and vacume advance are working properly. I would like to point out that I don't always practice what I preach and have put the cart before the horse:
I had a timing issue that I had dinked around with for a bit before I discovered half of the problem. The internal part of the hei shaft, the part that twists to advance the timing was seized up. Long after the problem, I have heard here on the board that the seized shaft is a common problem with hei distributors. I don't know the year of my hei because it was a freebee bone lying around, but I belive it is about the same vintage as your distributor.
