What battery did pontiac orginaly use in their Firebirds? I need a new battery and since I've tried to keep things as orginal as possible it would be nice to get a battery as close to the orginal as possible too. As least the same brand.
I just put my R59 in- my engine is all stock except for 10:1 compression. no problems- starts right up nicely. This battery does have less cold cranking amps than a top of the line new battery, but you don't need the extra amps unless you have a highly modified engine or unless something is wrong, like your timing.
Don't know. Mine is almost two years old and so far so good. But time will tell. I put a charger on it regularly during the winter downtime. You will have to buy acid at the local auto parts store to activate yours.
