The supplier depends on 1 of maybe 20 rebuilders for the industry. 95% of the time what store A through F has in stock at one point in time, usually diminishes or is an on demand from a wholesale hub.
I recommend calling NAPA, Autozone or Advance Auto and asking the specs. What master I bought 2 years ago at NAPA may or may not be available.
Si Vis Pacem Parabellum
Howdy sixstarved I thought you would know. Do you think this will work with the C5 discs (front and back)or is the stroke to short? Want to go manual. I know I can use the 15/16 S10 QTU but not sure it would provide enough presure or volume for the C5 calipers.
Howdy Does anyone know if the 88 S10 15/16 master cylinder will work with the C5 brakes(front caliper duel 40mm and back caliper single 45mm)? Don't know what the stroke is and keep reading it will and it won't work. Would like to be able to buy a replacement at the local parts store when it is time to replace the worn out one. If not I will use the CNC dubble 3/4 master cylinder just wont be able to replace at the local parts store. And of course I can't find info on it such as demensions and stroke but it should work.
