check your fuel lines for a restriction.you may have a kink in one of the hoses or steel lines.if that dont work,take the line off the fuel pump and tank and try to blow air through it.if you can blow air through it,you did something wrong when you installed the sending unit.make shur your fuel pump is working before you do anything.pour some gas in the carb and put your finger over the inlet of the fuel pump to see if it is sucking.
years ago, when i changed mine, i snapped the tiny ground wire when removing the tank, and nearly forgot about it when i put it back in. i say "nearly" because, after it wouldn't start, i knew what i had done. :rolleyes:
It will take more than 3 gallons of fuel in the tank to get it to pump. The tanks are about 18 gal. while you can only usually put 15 gal. in at any point in time. So 3 or more gallons of fuel will be required to get it all flowing.
Hope it is just that simple for you! Good luck - Brett - 67 Drop Top 455!
Thanks alot Brett! lol Just a year too late w that info. ,thats exactly why I now have an 'extra' tank for 69....! I ran out of gas , filled it up ,only got 15 gals. in it...thought former owner had put a 'cheap' 15 gal tank on and decided to replace w the 'real' thing! got my 18 gal from Classic including new straps ( since I knew 18 must be larger than 15 I wouldnt be able to re-use the old ones!) , installed tank and found they were the same size! ended up using the same straps , sold the extra ones , now stuck w an almost new used tank that cannot be shipped! Trying to GIVE it away , but needs to be to someone that can pick it up in Houston...
Aw Bjorn, you know your not truly happy unless you can hunt down a part, and replace something at least once a month on the bird! I think you just wanted to have a shinny tank, instead of a painted one! Lol...
doh! I hate it when I buy new parts for no reason!
hehehe
Check all of your rubber fuel lines, the one going from sending unit to the fuel line near the gas tank, theres one underneath the fuel pump, and one under the passenger side exhaust manifold, or at least thats what is on my 69. After re-installing my gas tank I noticed the one coming from the sending unit was kinking up. When reinstalling the gas tank I found it's best to go slow and check everything as you get it back in place.
i dunno . . . try running a line from a can of fuel to the pump inlet from a gas can. just to eliminate the rear portion of the fuel system. then you can be absolutely sure you're working in the right direction. even new fuel pumps can go bad. you can do everything right and still have a problem somewhere. let us know what it ends up being. i'm getting more curios everytime i check in.
nothing yet here guys. I am hoping not to have to drop the tank seeing it was kind of bear to strap in, besides i kept putting more and more fuel in it. although im bumming to run this new car.
A little gas tank trivia: Stock cars had to drag race with full tanks, and tanks were checked with a stick.
Pontiac was known for its cheating at hp rating and other things. The installation of the tank was yet another way that Pontiac cheated.
Instead of mounting the tank so that it would hold 18 gallons, Pontiac mounted the tank tilted upward so that a large air pocket remained, thus, the reason why you can only squeeze 15 gallons into the 18 gallon tank.
This is how I'd tackel the problem. First, I'd verify that the gas indeede comes out of the sending unit. Use an electic feul pump or safely run a test line.
Next, I'd attach a feul source to the line and see what happens. It's has to be one or the other because I realize that you're intellegent enough to know that if you had a vent problem, it would start, and run for however long; then, you'd get a vacume release when you removed the cap.
