10 BOLT 8.2 PONTIAC REAR DIFFERENTIAL PARTS FOR SALE
NEW AUBURN POSI 419.00 3.36-4.56 RATIO RECONDITIONED GM SAFTY TRAC POSI 325.00 2.93-3.23 RATIOS AXLE SHAFTS 29.75 28 SPLINE BOLT IN AXLES 125.00 EACH 3.55 GEARS NITRO GEAR AND AXLE BRAND 249.00 A SET REBUILD KIT 109.00 HAS EVERYTHING TO INSTALL THE POSI AND OR RING AND PINION LISTED BELOW- 2 carrier bearings and races 1 inner pinion bearing and race 1 outer pinion bearing and race 1 Pinion seal 1 pinion crush sleeve 1 pinion nut 1 rear inspection cover gasket 1 carrier pack of carrier shims 1 pinion pack of shims 1 marking compound and applicator brush 10 ring gear bolts 1 booklet to help you with your set-up pattern and torque specs. SHIPPING WILL VARY ON THE ZIP CODE YOU ARE AT- PM OR CALL 330 990 8155 JIM AKRON, OH
I bought all the replacement parts I needed to rebuild my 65 & 68 rear ends from Jim and everything fit perfectly. Count on Jim to know and have the parts you need.
I have a NEW Eaton that was NEW ring gear mounted and removed...
great deal at 459.00 a regular 559.00 retail price. this unit holds 3.36-4.33
Also have a New Auburn Posi unit with bearings for the 2.93 3.08 3.23 ratio rears. 409.00 Again can not sell them for absolute new because carrier bearings are mounted and ring gear was mounted and removed. Get a deal before the holiday!
