If you want to stick with stock ride quality you can order four-leafs bent to whatever height you want from Eaton Spring. They'll ship 'em right to your door.
I'd stick with the rubber bushings. Avoid the poly as they're prone to squeeking and further stiffen the ride (just a bit - less give).
