The speedometer DRIVE gear is on the tailshaft of the transmission. You can't remove it without removing the tailshaft housing. The speedometer DRIVEN gear is the one your speedometer cable plugs into. It can be removed by removing the plate where the speedometer cable screws on. The number of teeth on both gears matters.
