I guess the engine is coming out
Re: I guess the engine is coming out
03/21/10
02:25 PM
Dec 2006
ATLANTA, GA
GADJIT
GADJIT
Dec 2006
ATLANTA, GA
i was thinking rod knock or wrist pin. The motor is so hot that you cant hear the knock above idle very well and the plug wire test doesnt change it.
can you pull the oil pan with the engine in the car and get to the rod bearings and caps to check both these possibilities?
David
Subject
Posted By
Posted
GADJIT
03/21/10
06:46 AM
07:37 AM
Earlybird
03/21/10
07:41 AM
07:46 AM
GADJIT
03/21/10
06:25 PM
07:55 PM
07:57 PM
GADJIT
03/21/10
08:05 PM
CRommel
03/22/10
05:02 AM
FirebirdMike
03/22/10
05:07 AM
CRommel
03/24/10
05:09 AM
ho4spdtogo
03/25/10
06:40 PM
CRommel
03/28/10
05:40 PM
Switch to Flat Mode
0 members (), 1,243 guests, and 17 robots.
Highlander
May
