Yes, the bottoms of the door panels screw through the carpet (on the door panels). The screws have shoulder washers, and I think there are four or five of them across the bottom.
The arm rests should have a couple of screws into the door frame assembly.
To clarify, are your doors (meaning the door latch and window crank assemblies)set up for standard or deluxe door panels? That will also make a difference. The deluxe door panels require longer spindle assemblies.
