If the engine is in the car, put it in gear, put on the emergency brake, chock the wheels, and use a 3 foot pipe on a stout socket wrench. Once the bolt is out, the balancer usually slides right off. And it's a right hand threaded bolt.
Works OK for a stick shift. Otherwise the motor just spins along with the torque converter.
