Block offs go between the front bumper and radiator core support. Fills in that big hole on each side of the hood latch.
Underside baffle isn't as important but definitely would help.
Water pumps are hit and miss finding a cast impeller, I've run both without issue though. Just make sure whatever you get doesn't scrub the divider plate. Once you pull the pump make sure the plate is in good shape, also you'll see two tubes that go from the divider into the Timing cover, check them for condition and that their rubber O ring gaskets are in place.
Simple stuff, but if you haven't worked on a Pontiac it's just one more quirky thing about them.
newby with 68 firebird that runs hot Rockman 07/22/10 06:01 AM
Re: newby with 68 firebird that runs hot Dave's Langley '68 Droptop 07/22/10 07:34 AM
Re: newby with 68 firebird that runs hot David69bird 07/22/10 03:22 PM
Re: newby with 68 firebird that runs hot ho428 07/22/10 03:22 PM
Re: newby with 68 firebird that runs hot salmon38 07/22/10 04:48 PM
Re: newby with 68 firebird that runs hot Jimc2002 07/22/10 05:23 PM
Re: newby with 68 firebird that runs hot Region Warrior 07/29/10 09:13 PM
Re: newby with 68 firebird that runs hot Earlybird 07/29/10 09:32 PM
Re: newby with 68 firebird that runs hot Rockman 07/22/10 05:27 PM
Re: newby with 68 firebird that runs hot salmon38 07/22/10 05:32 PM
Re: newby with 68 firebird that runs hot Dr. Drivability 07/22/10 05:39 PM
Re: newby with 68 firebird that runs hot ho428 07/22/10 06:10 PM
Re: newby with 68 firebird that runs hot Rockman 07/22/10 11:33 PM
Re: newby with 68 firebird that runs hot Rockman 07/22/10 11:47 PM
Re: newby with 68 firebird that runs hot Jimc2002 07/23/10 12:47 AM
Re: newby with 68 firebird that runs hot colorado68 07/23/10 02:34 AM
Re: newby with 68 firebird that runs hot Rockman 07/28/10 05:40 AM
Re: newby with 68 firebird that runs hot Bronze Bird 07/28/10 07:18 PM
Re: newby with 68 firebird that runs hot nashville68bird 07/28/10 10:17 PM
Re: newby with 68 firebird that runs hot ho428 07/28/10 10:27 PM
Re: newby with 68 firebird that runs hot Bronze Bird 07/28/10 10:55 PM
Re: newby with 68 firebird that runs hot ho428 07/28/10 11:06 PM
Re: newby with 68 firebird that runs hot Bronze Bird 07/28/10 11:13 PM
Re: newby with 68 firebird that runs hot ho428 07/28/10 11:34 PM
Re: newby with 68 firebird that runs hot Rockman 07/29/10 05:31 AM
Re: newby with 68 firebird that runs hot Rockman 07/29/10 05:46 AM
Re: newby with 68 firebird that runs hot Earlybird 07/29/10 06:08 AM
Re: newby with 68 firebird that runs hot Bronze Bird 07/29/10 07:37 PM
Re: newby with 68 firebird that runs hot ho428 07/29/10 08:49 PM
Re: newby with 68 firebird that runs hot Bronze Bird 07/29/10 10:51 PM
Re: newby with 68 firebird that runs hot Rockman 07/30/10 02:50 AM
Re: newby with 68 firebird that runs hot nashville68bird 07/30/10 04:41 AM
Re: newby with 68 firebird that runs hot nashville68bird 07/30/10 04:51 AM
Re: newby with 68 firebird that runs hot Rockman 07/30/10 05:29 AM
Re: newby with 68 firebird that runs hot Michigan Larry 07/30/10 03:24 PM
Re: newby with 68 firebird that runs hot Earlybird 07/30/10 04:01 PM
Re: newby with 68 firebird that runs hot Earlybird 07/30/10 04:15 PM
Re: newby with 68 firebird that runs hot Rockman 07/30/10 04:59 PM
Re: newby with 68 firebird that runs hot ho428 07/30/10 05:08 PM
Re: newby with 68 firebird that runs hot Bronze Bird 07/30/10 05:27 PM
Re: newby with 68 firebird that runs hot Rockman 07/30/10 09:20 PM
Re: newby with 68 firebird that runs hot hslager69 07/30/10 10:33 PM
Re: newby with 68 firebird that runs hot Bronze Bird 07/30/10 10:52 PM
Re: newby with 68 firebird that runs hot Yellowbird 07/31/10 01:37 AM
Re: newby with 68 firebird that runs hot Rockman 08/09/10 06:44 AM
Re: newby with 68 firebird that runs hot Bronze Bird 08/09/10 06:48 PM
Re: newby with 68 firebird that runs hot ho428 08/09/10 07:59 PM
Re: newby with 68 firebird that runs hot Rockman 08/09/10 10:09 PM
Re: newby with 68 firebird that runs hot ho428 08/09/10 10:45 PM
Re: newby with 68 firebird that runs hot Rockman 08/12/10 09:25 PM
Re: newby with 68 firebird that runs hot Rockman 08/13/10 02:17 AM
Re: newby with 68 firebird that runs hot Rockman 08/14/10 02:20 AM
Re: newby with 68 firebird that runs hot catalina 08/14/10 02:33 AM
Re: newby with 68 firebird that runs hot Rockman 08/14/10 03:29 AM
Re: newby with 68 firebird that runs hot catalina 08/14/10 03:34 AM
Re: newby with 68 firebird that runs hot Bronze Bird 07/30/10 04:47 PM
Re: newby with 68 firebird that runs hot Bronze Bird 07/30/10 04:48 PM
Re: newby with 68 firebird that runs hot 6fbodies 08/16/10 06:07 AM
Re: newby with 68 firebird that runs hot Rockman 08/23/10 04:43 AM
Re: newby with 68 firebird that runs hot Earlybird 08/23/10 07:03 AM
Re: newby with 68 firebird that runs hot FirebirdMike 08/23/10 03:14 PM
Re: newby with 68 firebird that runs hot Rockman 08/23/10 04:21 PM
Re: newby with 68 firebird that runs hot hslager69 08/23/10 07:47 PM
Re: newby with 68 firebird that runs hot 69convertable 08/24/10 05:18 AM
Re: newby with 68 firebird that runs hot Rockman 08/24/10 04:26 PM
Re: newby with 68 firebird that runs hot colorado68 07/22/10 07:06 PM
Re: newby with 68 firebird that runs hot Dave's Langley '68 Droptop 07/22/10 07:25 PM
0 members (), 1,611 guests, and 74 robots.
